legohead Публикувано Февруари 1, 2019 Share Публикувано Февруари 1, 2019 Днес благодарение на @mamun научих за следния неоригинален продукт, съвместим с LEGO Technic В края на този коментар ще публикувам информацията и споделените мнения за този продукт. Ето кратко описание на английски какво съдържа комплекта: A complete 2.4 GHz TECHNIC Wireless control set CADA DETECH brands The controller has 4 independent channels (you can connect up to 4 motors or Serv) Compatible with lego, you can connect motors and servos from LEGO Technic 7.4 V voltage LI-ion 500 mAh battery capacity PERFECTLY COMBINED WITH LEGO TECHNIC. QUALITY, PATTERN, AND ANIMAL COLORING LEG. LINE: DeTECH equivalent of Lego Technic a set of new components - from completed factory sets it is not a set from a regular manufacturer's offer and is not treated as a separate factory product, but as a set of elements checked before shipment in terms of correctness of operation I give you a 2 weeks initial warranty The composition of the set Transmitter - 2.4GHz four-channel PILOT with reverse sides for each channel 2.4GHz four-channel receiver combined with a 7.4V battery USB charging cable instruction in English Споделени коментари: Цитат This is really cool, and honestly what Powered Up should have been from the start. Цитат This week I received the controller. I have tested it yesterday and I am pleased with how it works. The range is limited to 10-12 meters. Up to 6 meters (or so) the response is pretty fast, after that there is a slight delay. Цитат The controller is very comfortable to use and the position of the buttons is very well thought out. It's just like operating a Playstation or XBox controller. One thing that could be improved is the ability to rotate the two main levers, like the new Powered-up controller. Other than that this is the perfect solution for a model with four motors, one for driving, one for steering and the other two to operate two functions. The shoulder buttons both make the motor move in opposite directions. I'd rather give this remote to my nephews (or kids in general) than my smart phone. I have not tested how long the battery box will last until it needs to be recharged. But since you can charge it via USB, it's very easy to charge it again. I definitely recommend getting a unit, especially given the price. Not sure about the durability, but I am happy I got one :thumbup: But based on the look of the controller with the big levers I expected speed regulation for the blue and the red output, but they are just simple buttons, and only allow full throttle. I'm new in Technic electronics. I tried this controller+battery box combo, because the battery box looks better, than original Lego (rechargable, 4 outputs and cheap), while the simple controller fits better for me, than the mobile phone controlled PUP or BuWizz. I'm disappointed with the reduced capabilities of the controller, but the 2nd best solution, the BuWizz, is much more expensive. 6 Източник:https://www.eurobricks.com/forum/index.php?/forums/topic/167699-cada-battery-with-4-motor-outputs-and-remote-control/&page=3 Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
mamun Отговорено Февруари 1, 2019 Share Отговорено Февруари 1, 2019 Владо от форума на Брикмания ги е намерил. Аз само препредадох информацията 1 Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
legohead Отговорено Февруари 1, 2019 Автор Share Отговорено Февруари 1, 2019 Ти си свързващото звено м-у двете платформи Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
legohead Отговорено Март 12, 2019 Автор Share Отговорено Март 12, 2019 Благодарение на @Ratart се сдобих с приемника от AliExpress. Разбрах, че и @Ky4eразполага с такъв контролер. Ще споделя hands-on-expreneice при първа възможност! 2 Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
Ky4e Отговорено Март 18, 2019 Share Отговорено Март 18, 2019 Моята батерия спря да се зарежда след едно пълно зареждане. При зареждане с "оригиналния" кабел премигва лилаво-червено, но колкото и да седи и да се зарежда, след изключването на кабела не се стартира - при натискане на бутона за включване, светва червено и веднага изгасва. 1 Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
legohead Отговорено Март 18, 2019 Автор Share Отговорено Март 18, 2019 Все още не ми е останало време да тествам. Говорих с @abixbg, който също се сдоби с този приемник & дистанционно. Той ми сподели, че е заредил приемника (батерията) използвайки оригиналния USB->MicroUSB кабел и зарядно за телефон. След около час - два е получил идникация, че батерията е заредена. Когато имам възможност ще тествам и ще потвърдя дали при мен също се зарежда безпроблемно. Молба:@Ky4e, дали мога да те помоля АКО имаш някакви материали - ръководство, инструкции и тн. за твоя модел на количка с дистанционно управление CaDa (Double Eagle) да ги споделиш във форума? Благодаря! Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
Ky4e Отговорено Март 20, 2019 Share Отговорено Март 20, 2019 Ръководство имам, а каква е идеята точно? Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
legohead Отговорено Март 20, 2019 Автор Share Отговорено Март 20, 2019 Не съм успял да намеря инфо в нета, или по-скоро не съм отделил необходимото време да я търся Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
Ky4e Отговорено Март 20, 2019 Share Отговорено Март 20, 2019 Но инфо за какво? Защото ръководството, за което предполагам говориш е на китайски :D, но няма нищо интересно - показва кой бутон за кой канал е... Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
legohead Отговорено Март 21, 2019 Автор Share Отговорено Март 21, 2019 Ето това си направих вчера набързо. Използвал съм шасито от 42037, като съм го удължил с 2 единици.https://brickset.com/sets/42037-1/Formula-Off-Roader Ето и кратко видео как се движи: Като за контролер, който не позволява прецизно управление на скоростта на движение съм доволен P.S. Не шофирам аз :)) Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
legohead Отговорено Март 21, 2019 Автор Share Отговорено Март 21, 2019 Намерих ръководството и го споделям с вас: Цитирай Адрес на коментара Сподели в други сайтове More sharing options...
